mobile hotspot
1 TopicEx6200 wont extent windows 10 mobil hot spot
Using a laptop connected to ethernet cable using windows mobile hotspot on a laptop and it works fine, I can connect multiple devices to it no problem... but with the extender it gives no IP or actually make the window mobile hotspot dropout. the initial set up of the extender works but then the pc with hotspot drops all the connections or wont give an IP1.3KViews0likes1Comment
