nightcasters
Sep 03, 2017Follower
Ex6200 wont extent windows 10 mobil hot spot
Using a laptop connected to ethernet cable  using windows mobile  hotspot on a  laptop and it works fine,
I can connect multiple devices to it no problem...
but  with  the extender it gives no  IP or actually make the window mobile hotspot dropout. the initial set up of the extender works but then the pc with hotspot drops all the connections or wont give an IP
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Nightcasters
have you tried to assign a static IP from the hotspot to the extender?
DarrenM
