nightcasters
Sep 03, 2017Follower
Ex6200 wont extent windows 10 mobil hot spot
Using a laptop connected to ethernet cable using windows mobile hotspot on a laptop and it works fine, I can connect multiple devices to it no problem... but with the extender it gives no ...
DarrenM
Sep 06, 2017Sr. NETGEAR Moderator
Hello Nightcasters
have you tried to assign a static IP from the hotspot to the extender?
DarrenM
