network segmentation
1 TopicFeature request: provide true network segmentation for guest wifi
It would be great if you could improve the guest wifi capabilities, at least giving the option of complete network segmentation for guest networks on your routers. Visitors, and untrusted devices (e.g., IoT devices) should be able to connect to a separate SSID, on a (separate) VLAN (or other logical segmentation), so that guest devices can't discover, communicate with, or sniff traffic from, devices on the trusted SSID, except as explicitly permitted through user-created rules. Ideally, VLAN management should also extend to the ethernet ports on the router and satellites, so that wired devices can also be segmented out to the untrusted VLAN (e.g., wired IoT devices).8.2KViews25likes4Comments
