not showing up
2 TopicsR7800 stops showing bandwidth usage for devices
When I'm checking my "Attached Devices" it does not show the bandwidth usage from any device, even if the device(s) are using the internet. I have "Enable Auto Refreshing" checked. The only way for me to see it work is to reboot the router, but after a while it stops again. I thought the last firmware update had fixed it but I was wrong. OS: Windows 8.1 (64-bit) Firmware: V1.0.2.36 Browser: Google ChromeSolved2.3KViews0likes2CommentsPLEX does not show up in APPs on 6.6.0 Ready NAS 104
I have 6.6.0 firmware. I know this used to show Plex under "APPS". Now it does not. I have read the other thread that is marked solved, but it's unclear what "solved" it. That thread mentions multiple random factory resets and also mentions downloading PLEX from PLEX and uploading it to the NAS. I'd like to know what the real solution or next steps are to troubleshoot this issue. I would rather not do a factory reset. I think I actually had it set up once, and removed it. Now I'm ready to focus on it, but it's not showing up.7.7KViews0likes45Comments
