shade1989's avatar
Oct 15, 2017
R7800 stops showing bandwidth usage for devices
When I'm checking my "Attached Devices" it does not show the bandwidth usage from any device, even if the device(s) are using the internet. I have "Enable Auto Refreshing" checked. The only way for me to see it work is to reboot the router, but after a while it stops again. I thought the last firmware update had fixed it but I was wrong.
OS: Windows 8.1 (64-bit)
Firmware: V1.0.2.36
Browser: Google Chrome
  • Hi shade1989,
    Did it work prior to upgrading the firmware?
    Try to reset the router to default and reconfigure.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi shade1989,
    • JamesGL's avatar
      JamesGL
      Hi shade1989,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
