not working
1 TopicNetgear RX7500 2,4 Ghz network not working anymore
Hello together, some days ago, I saw on my router, that there is a update. After I installed the newest version, which is V1.0.0.108, I first found out, that the connection speed for all clients was just terrible. The router was not able to provide more then 20MBit/s out of a 200MBit/s connection. After a fresh reinstallation by reset the router, the speed was just fine. I've tried to restore my backup, I did just before the reset but than, the router was back to 20MBit/s. So, I had to configure everything from scratch (including reserev IPs for more than 20 devices, port forwarding for NAS, printer etc.) Finally it worked with the full 200MBit/s but a day later I've recognized, that I#m not able to find the 2,4Ghz WLAN anymore. So, I reconfigured it and it was visible for approximately 20 minutes. After that, the 2,4 connection was gone again. At all the time, my 5Ghz connection was working normal. Some hours ago, I tried to reconfigure the 2,4Ghz network to work again but with no success. 10 minutes it worked, after that, it disappered. May you please help me fix this issue? Thank yoiu MichaelSolved6KViews0likes4Comments
