os x
2 TopicsLink Aggregation with macOS
Hi, I've got two ethernet ports on my Mac mini and have bonded them together with the virtual interface. I've then plugged them both into my GS116Ev2. If I have LAG turned off the Ethernet bond from macOS connects just fine - if I turn LAG on, it disconnects and reports that my switch doesn't support link aggregation. What's going on here? Why are they working with LAG turned off, but not on? Are they even working with an aggregated connection with LAG turned off (is the Mac doing it instead?) should they work with it on?SolvedNot able to see NAS V2 in Mac Finder
I'm unable to see the NAS V2 in my MaC's Finder. IP address of the laptop's wifi and the NAS (found via Raider) is the same except for the last digit. The NAS is connected to the same wifi router as the pc is paired to. Laptop is running OS X El Cappitan 10.11.3 Product code is: ReadyNASRND2000v2 which is not listed in the pull down. Firmware: RAIDiator 5.3.11 Many thanks Gerry3.5KViews0likes12Comments
