pro router
1 TopicOrbi Pro - SRR60, SRC60, RBS50Y problem
Hello, I have a wifi system in our store with a SRR60 Router, two SRC60 indoor satellites and one RBS50Y outdoor satellite. I am having problems with our ESP32 (arduino) devices that they keep loosing wifi connection randomly after about 30mins to 2 hours, when it happens , they "think" they are connected to wifi, but do not get there assigned IP adres, so they wont reconnect on there own to fix it. My other devices also seem to sometimes loose connection (laptops, google chrome's, ...) but they usualy just reconnect fine on there own (sometimes you have to manualy reconnect) Is there any setting I can try to switch to fix this ??? , it makes them unusable because those ESP32's are used for temperature monitoring. I 100% narrowed the problem down to the Orbi's wifi, When I switch my Orbi system to AP mode and use another router for the IP adresses, same problem, if I simply connect a very old wifi router (with DD-WRT custom firmware) and connect this TO the orbi system as an extra AP and make the ESP32's connect to this wifi , they stay online for ever (day's tested) So the problem is 100% the wifi of the ORBI system, I have tried connecting to all 3 wifi's (main wifi, customer wifi, iOT wifi) that I can set up, I have tried splitting the 2.4Ghz and 5.0Ghz networks , I have tried with DHCP router modus and with AP modus with another router doing the DHCP, I have tried with fixed IP's for the EPS32's, the only thing that fixes the problem is NOT to use the netgear orbi wifi :( Anyone got any suggestions for me ? or should I just bin this crap ?? (they never realy where any good in my opion , always had small problems with them, but now with the EPS32 problem they are just plain not usable) Any help is appreciated, thank you, Hans331Views0likes8Comments
