pro router
11 TopicsIPSec Tunnel Not Starting
I have two PR60X with a IPSec tunnel connecting them over Verizon FIOS Business GB WAN connection. Tunnel ran fine without errors for almost 1 year. My IPSec tunnel stopped working after upgrading both PR60X to firmware V3.0.0.105. It was down for almost 24 hours and suddenly the tunnel started working without any changes. I double checked the IPSec configuration on both devices. No misconfiguration or changes. I powered down one PR60X to change location in rack, reconnected the router, but no IPSec tunnel. Waited approximately 10-11 hours and for some reason ... IPSec tunnel was working again. Anytime I reboot the router, the IPSec tunnel required 10-24 hours for it to start working again. Never had this problem with previous firmware. Any thoughts?51Views0likes2CommentsBR500 & Insight Support
I'm looking to get input on how I have them not renew the support by Insight given the fact that this unit is no longer supported. I can't seem to find any way to do it from my console or support page because this unit doesn't have support anymore and there doesn't seem to be a Insight support that seems readily accessible.. I've tried emailing support but that doesn't seem to go anywhere either.95Views0likes2CommentsPR460X crash
My PR460X on firmware 2.7.0.111 (current latest available) sometimes crashes. Stack trace from the crash logs below. This appears to be a firmware/driver bug. 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.476240] BUG: sleeping function called from invalid context at kernel/locking/rwsem.c:1559 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.476262] in_atomic(): 1, irqs_disabled(): 0, non_block: 0, pid: 0, name: swapper/3 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.483736] CPU: 3 PID: 0 Comm: swapper/3 Tainted: P 5.4.164 #0 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.491544] Hardware name: Generic DT based system 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.499016] [<4210fa8c>] (unwind_backtrace) from [<4210b870>] (show_stack+0x10/0x14) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.503608] [<4210b870>] (show_stack) from [<42738500>] (dump_stack+0x88/0xa8) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.511506] [<42738500>] (dump_stack) from [<4213e278>] (___might_sleep+0x13c/0x17c) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.518538] [<4213e278>] (___might_sleep) from [<42751ebc>] (down_write+0x18/0x70) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.526438] [<42751ebc>] (down_write) from [<42355ffc>] (debugfs_remove+0x24/0x60) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.533823] [<42355ffc>] (debugfs_remove) from [<3f7a8888>] (eip_ctx_final+0x38/0x68 [qca_nss_eip]) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.541396] [<3f7a8888>] (eip_ctx_final [qca_nss_eip]) from [<3f7ac310>] (eip_tr_inval_done+0x44/0x90 [qca_nss_eip]) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.550317] [<3f7ac310>] (eip_tr_inval_done [qca_nss_eip]) from [<3f7a8e88>] (eip_dma_napi_rx_poll+0x230/0x29c [qca_nss_ei p]) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.561080] [<3f7a8e88>] (eip_dma_napi_rx_poll [qca_nss_eip]) from [<425ffef8>] (__napi_poll+0x28/0xb8) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.572272] [<425ffef8>] (__napi_poll) from [<4260012c>] (net_rx_action+0xf0/0x280) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.581472] [<4260012c>] (net_rx_action) from [<42102148>] (__do_softirq+0xd0/0x280) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.589114] [<42102148>] (__do_softirq) from [<42120f20>] (irq_exit+0x74/0xd4) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.597097] [<42120f20>] (irq_exit) from [<42165810>] (__handle_domain_irq+0x90/0xb4) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.604129] [<42165810>] (__handle_domain_irq) from [<423ddc40>] (gic_handle_irq+0x58/0x90) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.612027] [<423ddc40>] (gic_handle_irq) from [<42101a78>] (__irq_svc+0x58/0x8c) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.620184] Exception stack(0xbe4c3f60 to 0xbe4c3fa8) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.627822] 3f60: 00000000 00014fd8 bedb2a34 42118140 00000000 ffffc000 00000000 42b06e48 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.632859] 3f80: 00000008 42b06ea8 42a41470 00000000 42b91730 be4c3fb0 42108b38 42108b3c 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.641017] 3fa0: 60000013 ffffffff 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.649177] [<42101a78>] (__irq_svc) from [<42108b3c>] (arch_cpu_idle+0x2c/0x38) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.652479] [<42108b3c>] (arch_cpu_idle) from [<42145038>] (do_idle+0xf8/0x274) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.660116] [<42145038>] (do_idle) from [<4214545c>] (cpu_startup_entry+0x18/0x1c) 2026-03-13T13:34:28+00:00 router.lan kernel: [ 40.667147] [<4214545c>] (cpu_startup_entry) from [<42102390>] (__enable_mmu+0x0/0x30)129Views0likes2CommentsPR60X Adguard login
Hello Sirs, Long time no see which means everything works fine except lack of IPV6 still. ( but its not important right now ) But could it be possible in the next firmwire update to add username/login for adguard DOH ? I, for exemple use https://adguard-dns.io which looks like https://d.adguard-dns.com/dns-query/XXXXX Right now I must use it on a adguard home lan server to able to do so and put it as dns for the lan using 192.168.1.X adresss in the PR60X configuration. Being able to put an argument in the adguard pr60X configuration would allow me to get rid of it. Thank you for your feedback.Solved195Views0likes2CommentsPR60X - Domain-Based Filtering in Firewall Traffic Rules
Dear Netgear Team, currently, the Traffic Rules feature only allows filtering based on IP addresses, ports, and services. While this works for many use cases, it is not sufficient for scenarios where modern services rely on dynamically changing IP addresses (e.g., CDNs or cloud-based endpoints). It would be highly beneficial to have the ability to define firewall rules based on domain names (FQDN). Ideally, this feature could include: support for FQDN in Traffic Rules automatic DNS resolution and IP updates in the background optional wildcard support (e.g., *.example.com) This enhancement would greatly improve real-world usability, especially in environments with IoT devices and cloud services. Thank you for considering this request. Best regards, Alex119Views0likes1CommentPR60X Cloudflare DDNS
I am getting an "Authentication unsuccessful" for my Cloudflare DDNS. I have tested my api token so I know it works. I think it may be the username. I have tried my email address tied to the api token, like the flavor text recommends. I have also tried my username, my Cloudflare Account ID, the default "Bearer". I think the username should be blank but the router will not let me. I have tried with both types of Cloudflare api tokens (user and account). Any help on this is highly appreciated.Solved392Views0likes4CommentsPR60X configured with dual WAN failover loses both connections every 2 hours
I have a PR60X with Metronet (T-Mobile) fiber (static IP) on WAN1 and Verizon Home Internet Lite (DHCP) on WAN2. Both connections are set to ping Google and Cloudflare DNS to determine online status. The router is not in Insight mode. However, after about 2 hours, I can no longer ping external IPs, even though the PR60X shows it has an internet connection. The only solution has been to reboot the PR60X. I'm running the latest firmware release. Any ideas?Solved644Views0likes7CommentsVPNG01L licence key activation
could anyone help me in resetting my licence key for activation? Although deinstalled on old laptop I can't activate licence on new one. I have no access to the old system as hard disc is wiped. After countless and friutless hours running in circles at Netgear Support pages you are my last hope... regards Bruno521Views0likes2CommentsFVS318v3 slow speeds as Router fast as Hub what settings can I change (internally on netgear)
My FVS 318 v3 is only 7 & 8 Mbps as a Router but it speeds up to (94 & 67 Mbps when modem cable is moved from WAN to a LAN port. what inside the Netgear is slowing down speed. No Port Fwrd, no Rules, no VPN, just basic AUTO setup.346Views1like3Comments
