redge9987
Jan 11, 2026Aspirant
PR60X Cloudflare DDNS
I am getting an "Authentication unsuccessful" for my Cloudflare DDNS. I have tested my api token so I know it works. I think it may be the username. I have tried my email address tied to the api token, like the flavor text recommends. I have also tried my username, my Cloudflare Account ID, the default "Bearer". I think the username should be blank but the router will not let me.
I have tried with both types of Cloudflare api tokens (user and account). Any help on this is highly appreciated.
The "Authentication unsuccessful" error in router-based DDNS setups is frequently caused by the router using an outdated Global API Key protocol rather than the modern API Token standard. If your router requires a username and won't let you leave it blank, it is likely expecting your Cloudflare email address paired with your Global API Key (found under My Profile > API Tokens), rather than a scoped Bearer token. If you must use a scoped API Token and the router demands a username, try entering token or bearer as a placeholder, but be aware that many older router firmwares simply do not support the Authorization Header format required for new tokens and will only work with the Global Key.
- maritn78uuujjeInitiate
- redge9987Aspirant
Yup that was it! My router wanted the full email address and the Global API key. I also corrected the "Domain" field. I removed my purchased domain name and instead placed my NS (Name Server). In my case the NS was "domaincontrol.com". Thank you for maritn for your help!
- c3po2Apprentice
Just a note: Beside using email / Global API key to authenticate with Cloudflare, Zone ID/Token authentication is also supported. Please check Cloudflare Zone ID for details.
- redge9987Aspirant
Thanks c3po - I just checked and it works great!
FYI forget my earlier post. Instead of a Name Server, the router wants a subdomain. So for future visitors of this forum, the "Domain" field, do "[email protected]" or something of the like. Here is what I did for my A record in Cloudflare:
Type: A
Content: current public IP
TTL: Auto
Proxy: OFF
