Retired_Member's avatar
Retired_Member
Dec 22, 2024
Differences between PR60X and PR460X Model Routers
I’m trying to decide which of these models of routers to buy to use with 2 WBE750 WAPs, an MS510TXUP switch, and an MS510TXM switch, all of which are Insight capable.
Are there any differences between the 2 models of routers besides length of warranty and length of included Insight subscription?
  • PR460X supports 3rd party application add-on, e.g. Domotz, it also supports Engage for Pro AV applications which PR60X does not support.
    • schumaku's avatar
      schumaku
      Starting from Netgear Engage v2.0, the PR460X Pro Router is (new with the WBE71x and the WBE75x) included in the supported products, see here.
      • Retired_Member's avatar
        Retired_Member
        Thanks. Since I’m planning to use the router for my home network, I don’t see a use for Engage or the extra features. I may still go with the PR460X for its longer warranty.
ProSupport for Business
