Retired_Member
Dec 22, 2024Differences between PR60X and PR460X Model Routers
I’m trying to decide which of these models of routers to buy to use with 2 WBE750 WAPs, an MS510TXUP switch, and an MS510TXM switch, all of which are Insight capable. Are there any differences be...
- Dec 22, 2024PR460X supports 3rd party application add-on, e.g. Domotz, it also supports Engage for Pro AV applications which PR60X does not support.
schumaku
Dec 22, 2024Guru - Experienced User
Starting from Netgear Engage v2.0, the PR460X Pro Router is (new with the WBE71x and the WBE75x) included in the supported products, see here.
Retired_Member
Dec 22, 2024Thanks. Since I’m planning to use the router for my home network, I don’t see a use for Engage or the extra features. I may still go with the PR460X for its longer warranty.
- c3po2Dec 22, 2024Apprentice
For home use, you may run Cloudflare speed test at speed.cloudflare.com from any PC on PR460X/PR60X LAN, with and without QoS (SQM - Smart Queue Management) enabled and compare network quality difference. The SQM may dramatically improve online gaming and video chatting quality depends on your Internet service. SQM reduces network latency (at cost of 10~15% bandwidth, many people have bandwidth far exceeding application needs, but there is always room for latency improvement)
