jsroman
May 27, 2026Aspirant
Pr60x SASE Security setting missing on Insight Portal
Do not see option to turn on SASE on Insight Portal. Router GUI does show Sase Security is off. Look on Insight Portal on device-security center and don't see option to enable SASE security. Any ideas?
- op3cNETGEAR Expert
SASE can only be enabled from Insight, please go to Settings/Security tab for PR60X to enable SASE.
Please note that SASE is only supported by "new" Insight, the "Legacy" mode Insight won't show SASE feature. Thanks.
- jsromanAspirant
Not seeing option under security tab. Security center tab shows: Firewall-Port Triggering-Port Forwarding-Service management and Dynamic DNS.
Please note that SASE enablement is available in new Insight only. If your Insight account has not been migrated to new Insight, please send request to NETGEAR support. Thanks.
Yrs, this applies to the Insight Premium accounts. Insight Pro accounts are (at least for me) migrated. According to support, the migration of Insight Premium (should) be done during the next week(s)
jsroman double check your PR60X is also updated to v3.
On my Insight Pro installations, this update was not pushed - the targeted version insisted to remain on v2.7. Have not investigated further, so updated the device from the local Web UI instead.
