rbe370 series
3 TopicsNew - RBE370/RBE371v1 Firmware Version 12.1.11.19 Released
Release Date: October 6, 2026 Enhancements: Enhances overall system stability. Security Fixes: This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security This version also has a new Protection Engine feature as well: https://community.netgear.com/discussions/en-home-routers-nighthawk-wifi-ax6/netgear-nighthawk---protection-engine-feature-faq/2407634 This is for the v1 version of the 370 series. Is NOT compatible with the v2 version. Download Link: https://www.netgear.com/support/product/rbe372/#download Firmware Update Instructions: To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/rbe372/#docs IF MANUALLY UPDATING THE SYSTEM: Be sure to update the RBS FIRST, then the RBR lastly. Please navigate to the link below for step-by-step instructions on how to update your RBR871/RBS870: Proceedure to Manually Firmware Update Orbi and Nighthawk Mesh systems I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. FW UPDATE ALL Feature: If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place. Recommend powering OFF the Orbi system for 1 minute then back ON with the RBR first then RBS after Update All completes. Give 5-10 minutes for system to fully come to ready. NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router: This sends a Factory Reset command to any and all connected RBS as well: Procedure for Factory Reset of RBE370 series systems use ERASE Button This article applies to: v1 version WiFi 7 (5) RBE370 RBE371 RBE372 RBE373 RBE374 Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi BE support forums. Orbi WiFi 7 (BE) Mesh Systems | NETGEAR Communities10Views0likes0CommentsNew - RBE260/360/370 Series Firmware Version 12.1.3.12 Released
Release Date: January 21, 2026 Security Fixes: This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security CVE-2026-0405 Authentication Bypass in NETGEAR Orbi Devices An authentication bypass vulnerability in NETGEAR Orbi devices allows users connected to the local network to access the router web interface as an admin. Severity: MEDIUM Download Links: RBE260 Series: https://www.netgear.com/support/product/RBE262 RBE360 Series: https://www.netgear.com/support/product/RBE362 RBE370 Series: https://www.netgear.com/support/product/rbe372 Firmware Update Instructions: To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/rbe372/#docs IF MANUALLY UPDATING THE SYSTEM: Be sure to update the RBS FIRST, then the RBR lastly. Please navigate to the link below for step-by-step instructions on how to update your RBR871/RBS870: Proceedure to Manually Firmware Update Orbi and Nighthawk Mesh systems I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. FW UPDATE ALL Feature: If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place. Recommend powering OFF the Orbi system for 1 minute then back ON with the RBR first then RBS after Update All completes. Give 5-10 minutes for system to fully come to ready. NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router: This sends a Factory Reset command to any and all connected RBS as well: Procedure for Factory Reset of RBE370 series systems use ERASE Button This article applies to: WiFi 7 (13) RBE260 RBE261 RBE262 RBE263 RBE360 RBE361 RBE362 RBE363 RBE370 RBE371 RBE372 RBE373 RBE374 Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi BE support forums. Orbi WiFi 7 (BE) Mesh Systems | NETGEAR Communities581Views0likes0CommentsNew - RBE370/RBE371 Firmware Version 12.1.3.11 Released
Enhancements: 9/18/2025 Enhances overall system stability. Bug fixes: Fixed an issue that caused custom satellite names to revert to default when using wired backhaul. Fixed an issue that caused Internet connectivity failure after upgrading firmware when VLAN is configured. Download Link: https://www.netgear.com/support/product/rbe372/#download Firmware Update Instructions: To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit https://www.netgear.com/support/product/rbe372/#docs IF MANUALLY UPDATING THE SYSTEM: Be sure to update the RBS FIRST, then the RBR lastly. Please navigate to the link below for step-by-step instructions on how to update your RBR871/RBS870: Proceedure to Manually Firmware Update Orbi and Nighthawk Mesh systems I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. FW UPDATE ALL Feature: If there is a FW updated seen on the RBRs web page and all RBS are online and connected with GOOD STATUS, you can select the UPDATE ALL button option to have the RBR update the RBS and RBR. Update All button is seen on the RBRs Firmware Update WEB page on the Check for Updates FW section of the page. Once FW has been checked for an update and all devices show the FW update is available, select the UPDATE ALL button. Give 5 minutes for the process to take place. Recommend powering OFF the Orbi system for 1 minute then back ON with the RBR first then RBS after Update All completes. Give 5-10 minutes for system to fully come to ready. NOTE: If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. Use the ERASE button on the routers web page to factory reset the router: This sends a Factory Reset command to any and all connected RBS as well: Procedure for Factory Reset of RBE370 series systems use ERASE Button This article applies to: WiFi 7 (5) RBE370 RBE371 RBE372 RBE373 RBE374 Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi BE support forums. Orbi WiFi 7 (BE) Mesh Systems | NETGEAR Communities594Views0likes0Comments
