rbk750 series
3 TopicsNew - Orbi RBK750/850/860/960 Series Firmware Version 7.2.8.5 Released
Release Date: December 04, 2025 Security Fixes: This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security Download Link: Orbi 960 Series: https://www.netgear.com/support/product/rbke962 Orbi 850 Series: https://www.netgear.com/support/product/rbk853 Orbi 860 Series: https://www.netgear.com/support/product/rbk862 Orbi 750 Series: https://www.netgear.com/support/product/rbk752 Please navigate to the link below for step-by-step instructions on how to update your Orbi model system:: https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co... Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities Be sure to update the RBS FIRST, then the RBR lastly. I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. The best advise we can give people is to start a new config, power on one RBS and wait for some SOLID light or most often blue or magenta. And then add the RBS WIRELESSLY via the WebUI. Power off the RBS. Then rinse and repeat with any additional RBS(s). Pair RBS one at a time even if you have more than one. For ethernet connected RBS, after things come up wirelessly, you can move to wired backhaul but don't start with wired backhaul for those RBS that are ethernet connected. Wirelessly connect and sync RBS first before ethernet connecting RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. A factory reset maybe needed if problems are encountered after the FW update: Orbi Systems Manual Factory Reset Process | NETGEAR Communities NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 This article applies to: RBKE962 RBKE963 RBKE963B RBKE964 RBKE964B RBKE965 RBKE965B RBRE960 RBRE960B RBSE960 RBSE960B Orbi (850 Series) RBK852 RBK853 RBK854 RBR850 RBS850 Orbi (860 Series) RBK862S RBK862SB RBK863S RBK863SB RBK864SB RBR860 RBR860B RBR860S RBS860 RBS860B Orbi (750 Series) RBK752 RBK752 RBK753 RBK753S RBK754 RBR750 RBS750 Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi AX and AXE support forums. Orbi WiFi 6/6E (AX & AXE) WiFi Systems | NETGEAR Communities Thank you.2.5KViews1like0CommentsNew - Orbi RBR/RBS 750/850/860 and 960 series Firmware Version 7.2.7.15 Released
Enhancements: 02/21/2025 Added Router Protection support. Bug Fixes: Fixed a WiFi connection stability issue. Fixed various bugs. Security Fixes: This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security For ALL Regions. Known issues: Breaks IPv6 support. If you need IPv6 WAN and LAN support, users are recommended to revert back to prior working FW version. NG has been made aware of this issue. Otherwise, disable IPv6 on the RBR for this version of FW. Download Link: Orbi 750 Series: https://www.netgear.com/support/product/rbk752/#download Orbi 850 Series: https://www.netgear.com/support/product/rbk852/#download Orbi 860 Series: https://www.netgear.com/support/product/rbk862s/#download Orbi 960 Series: https://www.netgear.com/support/product/rbke962/#download Please navigate to the link below for step-by-step instructions on how to update your Orbi model system:: https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co... Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities Be sure to update the RBS FIRST, then the RBR lastly. I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. The best advise we can give people is to start a new config, power on one RBS and wait for some SOLID light or most often blue or magenta. And then add the RBS WIRELESSLY via the WebUI. Power off the RBS. Then rinse and repeat with any additional RBS(s). Pair RBS one at a time even if you have more than one. For ethernet connected RBS, after things come up wirelessly, you can move to wired backhaul but don't start with wired backhaul for those RBS that are ethernet connected. Wirelessly connect and sync RBS first before ethernet connecting RBS. NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. NOTE: The Disable Auto Update feature only prevents ANY new FW from being installed if available. This does NOT prevent the system from checking NG services to see if new FW is available. If new FW is available, this will be displayed as a notification to the user on the RBRs web page only. It will be up to the user to upgrade FW or not. A factory reset maybe needed if problems are encountered after the FW update: Orbi Systems Manual Factory Reset Process | NETGEAR Communities NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 This article applies to: Orbi (30) RBK752 RBK753 RBK753S RBK754 RBR750 RBS750 RBK852 RBK853 RBK854 RBR850 RBS850 RBK862S RBK862SB RBK863S RBK863SB RBK864SB RBR860 RBR860B RBR860S RBS860 RBS860B RBKE962 RBKE963 RBKE963B RBKE964 RBKE964B RBRE960 RBRE960B RBSE960 RBSE960B Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi AX and AXE support forums. Orbi WiFi 6/6E (AX & AXE) WiFi Systems | NETGEAR Communities1.5KViews0likes0CommentsNew - Orbi 750/850 and 960 Series Firmware Version 7.2.6.21 Released
Enhancements: 09/08/2023 Supports Separate SSID IoT network. https://kb.netgear.com/000064267/How-do-I-enable-or-disable-the-Internet-of-things-IoT-network-on-my-Orbi-WiFi-6E-System https://kb.netgear.com/000064269/How-do-I-change-the-Internet-of-things-IoT-network-name-SSID-and-password-on-my-Orbi-WiFi-6E-System Mixed Mode WPA2/WPA3 Improves the stability of connections between router and satellites Improves satellite firmware upgrade stability Security Fixes: This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security. Knowns: CTS/RTC web ui no longer present. Unforseen issues with NG and the EU region, NG had to pull v7.x FW version from being pushed to 960 series users in the EU region. Manual updating is not supported as well. Seems there maybe some wifi policy that has to be figured out between NG and the EU region. We've asked about this and for now, it's a work in progress and NG is aware of it. So if your in the EU region, v6.x version of FW is all that is currently supported for the EU region users. Download Link: https://www.netgear.com/support/product/rbk752/#download https://www.netgear.com/support/product/rbk852/#download https://www.netgear.com/support/product/rbke963/#download Be sure to select the "Previous Versions" link to show all other versions of FW. NOTE: URL Links on the main download page for the RELEASE Notes are broke and not working. Release notes are included in the .zip files for review. We've made NG aware of this. The Download button links are working however. Firmware Update Instructions: To update your router’s firmware, follow the instructions in your router’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation link. NOTE: Update the RBS first, then the RBR lastly. I recommend doing a full on factory reset after the FW loads, system is back to ready and a power OFF for 1 minute then back ON has been performed. Use a wired PC and web browser for this. Load the FW on to each RBS web page using the RBS web page, not thru the RBRs web page. Then load the FW lastly on the RBRs web page. Walk thru the setup wizard. You can manually setup the system as well for those who are more experienced with this. https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelli... Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS. A factory reset maybe needed if problems are encountered: Orbi Systems Manual Factory Reset Process | NETGEAR Communities The best advise we can give people is to start a new config, power on one RBS and wait for some SOLID light or most often blue or magenta. And then add the RBS WIRELESSLY via the WebUI. Power off the RBS. Then rinse and repeat with any additional RBS(s). Pair RBS one at a time even if you have more than one. For ethernet connected RBS, after things come up wirelessly, you can move to wired backhaul but don't start with wired backhaul for those RBS that are ethernet connected. Wirelessly connect and sync RBS first before ethernet connecting RBS. NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. NOTE: The Disable Auto Update feature only prevents ANY new FW from being installed if available. This does NOT prevent the system from checking NG services to see if new FW is available. If new FW is available, this will be displayed as a notification to the user on the RBRs web page only. It will be up to the user to upgrade FW or not. This article applies to: Orbi (20) RBK752 RBK753 RBK753S RBK754 RBR750 RBS750 RBK852 RBK853 RBK854 RBR850 RBS850 RBKE962 RBKE963 RBKE963B RBKE964 RBKE964B RBRE960 RBRE960B RBSE960 RBSE960B Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi AX and AXE support forums. Orbi WiFi 6/6E (AX & AXE) WiFi Systems | NETGEAR Communities489Views0likes0Comments
