readyShare printer
1 TopicPrinting using Netgear ReadySHARE Printer function is not working.
Hi, Printing using Netgear ReadySHARE Printer function is not working. Router firmware is the latest: V1.0.1.12_1.0.11 My printer is a HP LaserJet 1020 USB printer, connected properly. In Netgear USB Control Center (Software Version 1.36, Driver Version 1.83.35) it shows the printer is connected to R6400. When I inititate printing from PC, the printer starts to roll rollers for about 3-4 seconds and stops without feeding in the sheet. On PC in printer properties / printer status first shows Printing and after cca 30 seconds goes to: Error - printing. After deleting the queued document, and try to print again, I get Error printing on HP LaserJet without printer roller activity. Roller rolls only first attempt after the printer is powered on. If I connect the printer trough USB to my PC, the printing is working properly. Please suggest solution, or how to troubleshoot this. Thanks, mloriSolved5.8KViews0likes3Comments
