readynas 312
4 TopicsReadynas 312 network issues
We have 6 ystems connecting to a share on our ready nas 312 and up until about two weeks ago everything was fine. The share is mapped to local systems as the "N" drive and everyone has read write access to the folder and sub-folders. Now when accessing a file - we somertimes receive a lost connection to network drive message which happens if we are already in an open file or accesing a folder. After 10 or so minutes access is reaqcuired and the file can be modified but it is making the system unusable. We are updated to the most current firmwar and recently I feel the issue caused the volume records in the system to get wiped out and Netgear tech support had to remote into the system to correct. Has anyone experienced this issue?767Views0likes1Commentcomputer can not connect to ReadyNAS 312 with out rebooting NAS
Just updated to 6.9.2 firmware. When i reboot my widows 7 computer i can not reconnect to the NAS via the shortcut in network locations. Only option is to connect via ip address and restart. Then reset the short cut error message --------------------------- Restoring Network Connections --------------------------- An error occurred while reconnecting Y: to \\Hd-ox2p\hd_ox2p Microsoft Windows Network: The network path was not found. This connection has not been restored. --------------------------- OK ---------------------------ReadyNAS 312 Vertical Expansion - First Time
We needed to upgrade a client from their existing 2Tb Raid 1, to a 6Tb Raid 1. I verified that the WD Black 6Gbs were in the acceptable (compatible: http://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List?cid=wmt_netgear_organic) list, and they were. Replaced the first, and as expected, over the course of a few hours, I went from degraded, to synced, and working fine without any issues. Second drive arrived the next day, and feeling confident in the process, I swapped the other drive. This process also went smoothly, and as I got home, the drive finished syncing, and showed a full Raid 1 mirrored condition. Still being a little wary of the expansion process, I verified that the system saw the new drives as full size, and they did. Both disks show at approx 5.5 TB. So, reboot. And Reboot. And Reboot.... And nothing. I've restarted approximately 8 times since the second drive was loaded, including at least one 24 hour window, with no change. The NAS shows no signs of "expanding" its size, or adjusting to the correct amount available. I thought that maybe, since it was running almost full (don't they always wait until the last moment to approve things?), I needed to clear a little space. So, deleting some older backups, I cleared 350Gb to work with. No change. What am I missing? I've had the company spend the money on two 6Tbs, and they don't have 6Tb to work with... Ideas? thanks! Firmware 6.6.1 XRAIDSolved6.5KViews0likes19CommentsTransmission add-on for ReadyNAS
Hi, I have installed the Transmission add-on version 3.0.0.8 from DEV "Poussin" on my ReadyNAs 312 (fw 6.2.4) but often the web UI of this add-on falls, and can't available anymore on installed port (8181 in my case) Do you know this issue? Where can I find a update Thanks :-) Yves7.9KViews0likes8Comments
