readynas for surveillance
2 TopicsCamera Magic
I recently purchased a RN42400 primarly for video surveillance. The product shows thousands of compatible cameras but on close inspection, most, if not all, of the cameras listed are no longer manufactured by the camera companies. I selected a camera from one of the listed manufacturers that is close to the model number of a supported camera according to ReadyNas documentation. I have the camera working on the network (yes it is a wired, not wireless (WiFi) camera) and can access the camera via the camera's provided software. I cannot find a way to get ReadyNas to find and work with the camera. Is there something I'm missing or is there anything (i.e. software configuration on either the camera of surveillance software) that needs to be done to make the camera work with the surveillance software provided with the ReadyNas?1.2KViews0likes3CommentsMilestone Arcus & ONVIF Camera
I am trying to install a ONVIF compatible camera in Milestone Arcus and I can get it to be detected but I cannot get an image. I have tried pretty much every setting but no luck. The camera is an Acti ACM-7411 which is not on the compatability list but the documentation says that if the camera is ONVIF compliant then it should work. Any suggestions?
