reset factory default
1 TopicReadynas Ultra 6 boot problem
Hi Everyone, I have a Readynas Ultra 6. Because of an power outage the Readynas won't boot anymore. - the fan's are working. - the display keeps showing 'readynas' - i found the vga header, but the monitor says 'no cable connected'. - I've replaced the memory. - I've have i disk in the unit and is spinning up. - I tried to restore factory by using a boot usb and the backup button. - i pressed the reset button (on the back) at power on. - I cannot access the bootmenu (display won't change from 'readynas') Can someone please help what else i can do to fix the boot problem. Greetings, Rob3.2KViews0likes10Comments
