Retired_Member's avatar
Retired_Member
Oct 22, 2016
Readynas Ultra 6 boot problem
Hi Everyone,
I have a Readynas Ultra 6.
Because of an power outage the Readynas won't boot anymore.
- the fan's are working.
- the display keeps showing 'readynas'
- i found the vga header, but the monitor says 'no cable connected'.
- I've replaced the memory.
- I've have i disk in the unit and is spinning up.
- I tried to restore factory by using a boot usb and the backup button.
- i pressed the reset button (on the back) at power on.
- I cannot access the bootmenu (display won't change from 'readynas')
Can someone please help what else i can do to fix the boot problem.
Greetings,
Rob
  • StephenB's avatar
    What do you see if you power down, remove the disk, and start up the NAS w/o it?
    Also, when you are running w/o the disk, does RAIDar see the NAS?
    • Retired_Member's avatar
      Retired_Member
      Hi Stephen B,
      Thanks for the quick response.
      I tried without a disk and the same message appeared (Readynas).
      I also tried to connect to the nas through my networ with RAIDar. Nothing was found.
      I tried both ethernet connectors.
      Also what i notice is that the light at the ethernet connectors are not lighting up (datatransfer).
      Nothing changed. display still shows "readynas".
      • StephenB's avatar
        Then something in the chassis has failed.
        Did you run the memory diagnostic?
  • This could be a power supply issue.  The display will say "ReadyNAS" with just +5V available.  The drive spinning up and fans on indicate you have the main 12V.  But there is a secondary 12V and a 3.3V bus that could have an issue.  If you have a spare ATX power supply (or can borrow one from a computer), you can connect it externally to the NAS and see if that fixes it.  If the temparary supply doesn't have the necessary 3 4-pin Molex connectors, it shouldn't matter since you only have one drive currently installed.
      Retired_Member
      Hi Sandshark,
      Sorry for the late response.
      I tried the following:
      From an old PC i removed the adaptor and connected it to the NAS.
      the only connection i made was with the 24 pin connector.
      So i did't  connect the HDD.
      The fan for the case starts spinning and only on the display 'readynas'.
      I left it running for about 5 minutes. Nothing changed.
      I also changed the memory, but this also nothing changed.
      Still only on the display 'readyNas'
ProSupport for Business
