Anonymous
Oct 22, 2016Readynas Ultra 6 boot problem
Hi Everyone, I have a Readynas Ultra 6. Because of an power outage the Readynas won't boot anymore. - the fan's are working. - the display keeps showing 'readynas' - i found the vga header, b...
Oct 22, 2016Guru - Experienced User
What do you see if you power down, remove the disk, and start up the NAS w/o it?
Also, when you are running w/o the disk, does RAIDar see the NAS?
Anonymous
Oct 22, 2016Hi Stephen B,
Thanks for the quick response.
I tried without a disk and the same message appeared (Readynas).
I also tried to connect to the nas through my networ with RAIDar. Nothing was found.
I tried both ethernet connectors.
Also what i notice is that the light at the ethernet connectors are not lighting up (datatransfer).
Nothing changed. display still shows "readynas".
- StephenBOct 22, 2016Guru - Experienced User
Then something in the chassis has failed.
Did you run the memory diagnostic?
- AnonymousOct 27, 2016
Hi StephanB,
Sorry for the late response.
This is nog possible, because I don't see anything than 'Readynas' on the display.
