Anonymous
Oct 22, 2016Readynas Ultra 6 boot problem
Hi Everyone, I have a Readynas Ultra 6. Because of an power outage the Readynas won't boot anymore. - the fan's are working. - the display keeps showing 'readynas' - i found the vga header, b...
Sandshark
Oct 22, 2016Sensei
This could be a power supply issue. The display will say "ReadyNAS" with just +5V available. The drive spinning up and fans on indicate you have the main 12V. But there is a secondary 12V and a 3.3V bus that could have an issue. If you have a spare ATX power supply (or can borrow one from a computer), you can connect it externally to the NAS and see if that fixes it. If the temparary supply doesn't have the necessary 3 4-pin Molex connectors, it shouldn't matter since you only have one drive currently installed.
- AnonymousOct 27, 2016
Hi Sandshark,
Sorry for the late response.
I tried the following:
From an old PC i removed the adaptor and connected it to the NAS.
the only connection i made was with the 24 pin connector.
So i did't connect the HDD.
The fan for the case starts spinning and only on the display 'readynas'.
I left it running for about 5 minutes. Nothing changed.
I also changed the memory, but this also nothing changed.
Still only on the display 'readyNas'
- mdgm-ntgrOct 27, 2016NETGEAR Employee Retired
This could suggest a PSU issue.
- SandsharkOct 27, 2016Sensei
You must also connect the square 4-pin connector, which supplies CPU power, at a minimum. But connecting everything and completely disconnecting the original supply is the only proper way to see if the power supply is the issue. It is unknown what load unpowered drives will place on the remainder of the chassis. You can leave the drives out, if you like. I believe you should get a "No Drive" indication on the display.
- AnonymousOct 28, 2016
Hi Sandshark,
So I connected the HDD.
Nothing changed.
The square 4-pin connector of the adapter I found hanging around in the case.
There is no scoket found on the motherboard for the square 4-pin connector !?
