satellite issues
2 TopicsOrbi Pro Orbi 6 (SXR80 - SXS80) Satellites won't connect
I have a Orbi Pro router that came paired with 2 satellites. I have had it for 4 years and recently if I have a power outage, like we have in OK often, my 2 satellites disconnect from the router and will not connect and these were pre-paired so they are supposed to just connect automatically. Since this problem started, I have tried many different things to get them reconnected, using all the published methods and they fail. One of the many times this happened recently, I tried all the basic reconnection steps and it failed, but then overnight it just healed itself and they both connected. The next time this happened I was not so lucky. Nothing would get them reconnected, even leaving things overnight. So, I did the only thing I knew to do which was to delete the satellites from my account and then use the method published for connecting a satellite that was not pre-paired. This worked, but only once. The next time I tried that method, it failed to add them back and I lost the use of the satellites for several days. I just gave up and used the router to provide internet to my 40 devices which was not ideal. After dealing with this a while I decided to continue troubleshooting and was able to get them reconnected, by doing the same things I had already tried and failed. Now I am stuck. I have manually removed the satellites from my account, in the insight app on my iphone, and this time, nothing will get them reconnected. I have officially thrown in the towel. This should not be required each time I have a power failure. I will get a battery backup, which should help, but I will have to get 3 since they are all in different rooms. Anybody have this same problem and solve it? Thanks in advance, RonSatellites not putting out wifi signal after upgrade to v1.12.0.18?
Reposting my concern in its own thread in hopes to get an answer from a netgear moderator or anyone else with a solution. -I have one router and two satellites; RBS50's -Firmware was updated automatically the other night. -Configured in router mode The satellites are NOT showing up under "Attached Devices" as satellites...they do however, show up under connected devices. Logging into their respective status pages by way of their listed ip, I see that both of my satellites are updated to this latest version and the wireless AP are listed as OFF, 2.4ghz & 5ghz are listed as disabled. The router itself is fine, putting out a wifi signal that I can connect to. The GUI states satellites are connected to it...how do I enable the wifi on the satellites so my devices can connect to them? I've tried powering down everything for 30 min and turning them back on, reinstalling on one satellite, resetting the other satellite and resyncing (which briefly showed up on the GUI as a connected satellite, but on it's status page, it said not connected) , all to no avail. Any insight or suggestions would be greatly appreciated.Solved
