satellite issues
1 TopicSatellites not putting out wifi signal after upgrade to v1.12.0.18?
Reposting my concern in its own thread in hopes to get an answer from a netgear moderator or anyone else with a solution. -I have one router and two satellites; RBS50's -Firmware was updated automatically the other night. -Configured in router mode The satellites are NOT showing up under "Attached Devices" as satellites...they do however, show up under connected devices. Logging into their respective status pages by way of their listed ip, I see that both of my satellites are updated to this latest version and the wireless AP are listed as OFF, 2.4ghz & 5ghz are listed as disabled. The router itself is fine, putting out a wifi signal that I can connect to. The GUI states satellites are connected to it...how do I enable the wifi on the satellites so my devices can connect to them? I've tried powering down everything for 30 min and turning them back on, reinstalling on one satellite, resetting the other satellite and resyncing (which briefly showed up on the GUI as a connected satellite, but on it's status page, it said not connected) , all to no avail. Any insight or suggestions would be greatly appreciated.Solved
