switch discovery tool
1 TopicSwitch Discovery Tool not showing connection
Used discovery tool for a long time - recently upgraded PC to Win 11 and now when I load the discovery tool it does not register (or give an option) to select the connection (Wired or Wifi adapers) to initiat the scan from. I turned off firewall in case it is that (but still fails to pick up the LAN interface. The Prosafe Plus utility does search and pick up the switches correctly. I've seen a few posts of others having the same issue. Any ideas how to get it to work?
