volume scan
3 TopicsReadyNAS Duo V1 file share permissions broken, can't create/delete files
Had my ReadyNAS Duo V1 for a few years now. File share permissions were working fine. Now, as of a couple weeks ago, I can't write or delete files from the shares. I still have read permissions it seems. I can copy files from the share but not to the share. I tried resetting the read/write share permissions using Advanced Settings from FrontView, but still broken.Solved3.3KViews0likes10CommentsReadyNAS Ultra 4 "Volume scan found errors that it could not easily correct."
Hi all! First time poster, long time lurker. After years of happy use of the Ultra 4, I have my first (major) issue. None of the shares are mounting, presumably due to the missing volumes. Further inspection indicates that the disk space is full "3940 GB (100%) of 3940 GB used". While I suspect this is a red herring, it's possible a runaway process filled it up. Following is a snippet of the most recent logs: Tue Feb 7 12:30:59 EST 2017 System is up. Tue Feb 7 12:29:59 EST 2017 The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. share1 share2 share3 Tue Feb 7 12:28:40 EST 2017 Volume scan found errors that it could not easily correct. Please ensure that you have current backups of all valuable data before performing a full volume scan by rebooting the NAS through Frontview with the volume scan option enabled. Sun Feb 5 06:41:28 EST 2017 RAID scrubbing finished on volume C. Sun Feb 5 03:03:28 EST 2017 The on-line filesystem consistency check completed without errors for Volume C. Sun Feb 5 03:00:03 EST 2017 The on-line filesystem consistency check has started for Volume C. Sun Feb 5 00:00:24 EST 2017 RAID scrubbing started on volume C. Sun Jan 29 06:43:35 EST 2017 RAID scrubbing finished on volume C. Sun Jan 29 03:03:29 EST 2017 The on-line filesystem consistency check completed without errors for Volume C. Sun Jan 29 03:00:03 EST 2017 The on-line filesystem consistency check has started for Volume C. Sun Jan 29 00:00:18 EST 2017 RAID scrubbing started on volume C. Sun Jan 22 06:43:26 EST 2017 RAID scrubbing finished on volume C. Sun Jan 22 03:03:35 EST 2017 The on-line filesystem consistency check completed without errors for Volume C. I do not have a current backup, and only have around 40GB on the NAS that is worth saving. Any way to mount these up temporarily to see if I can delete a gigantic file or save the vitals before a rebuild? Is Skip Volume Check the way to go? I'm on Ubuntu for debugging, but can also use Windows tools. Thanks for any help!3.9KViews0likes6CommentsVolume Scan Failed to Run Properly during boot
I have a ready nas business edition with iscsi enabled. It is running the latest firmware. If I reboot it normally without checking : Perform volume scan on next boot. This process can take several minutes to more than an hour depending on disk capacity and volume content. Check and fix quotas on next boot. This process can take several minutes to more than an hour depending on disk capacity and the number of files on your volume. the NAS boots fine, but if I try and check both or either of these two boxes, the NAS hangs during the boot process. I did get a notice awhile back that I needed to backup all data and check and repair volume. Please advise.2.8KViews0likes3Comments
