x86 Public Beta
13 TopicsOS6.2 On ReadyNAS Pro 6
Anyone have any experience installing R6 on this specific R4 unit? Any issues with the installation or post-intsall? I've been doing some reading. Is it really as simple as installing the R4toR6 prep addon and then updating the firmware with official 6.2 download? I realize a factory default is required as part of the process.5.2KViews0likes8CommentsUpdating to Beta OS6.2.3 build 11
i have a readynas pro 6 with OS6.2.3 build 9. It was giving some instability on the web front, so I decided to jump to build 11 as some of the notes were mentioning the web interface. Download the image, update via Web Interface, asked to reboot. So far, so good. When it reboot, the WebUI spash screen remains the same as before and a message pops up saying 'new firmware detected. Reboot to update'. I repeat the web step a couple of time, with similar results. I decide to go to the box. Hardware shutdown. Reboot, similar message: 'new FW detected, updating, rebooting'. After another hardware rough shutdown, the fw update actually updates. And things get back to normal. Bumpy ride.1.8KViews0likes0CommentsWake On Lan
I have been using Wake On Lan rather nicely with 6.x on various Legacy devices. Up to now all of them have used only one Ethernet connection. Now I'm using a Ultra 6 with both NICs bonded as Adaptive Load Balancing. I can still wake up the NAS using a Wake On Lan app but for whatever reason XBMC (13.2) won't wake up the Ultra 6. It still wakes up a PC so its appears to be working. My Wake On Lan app shows two entries for the NAS both with the same IP address and different MAC addresses and I can wake it up selecting either one. Now I did some casual testing with them bonded and didn't notice any performance increased with SMB. I believe I did see a boost with iSCSI... a decent increase in overall speed. I guess I'll remove the bonding and see if it then works but I'm wondering if anyone has run across such and if so any hints on getting it to work?4.3KViews0likes9CommentsBackup error 'destination is read-only', 6.2.3 (Beta 9)
ReadyNAS Ultra 2 Plus OS 6.2.3-T1751 (Beta 9) I connected the backup USB3-drive to the front USB3-port. One of the six backup jobs now get the "Backup: Error backup job 'xxx': destination is read-only". Files have been copied though. The backup_002.log file says "status: 13". The backup_002_error.log file is empty. I did not run this now failing backup job on all previous Betas, so no track record. To get pass this problem I deleted the backup job and the destination folder and created a new backup job with the same source and destination. Another thing to be mentioned that I think has been there for a while: In the Backup tab there is the Status column. If starting several jobs they are put in "queue" state and executed one at a time and get "in progress" state. Often when a job is comleted there is no "completed" state. To know which jobs is comleted you have to use the refresh button.3KViews0likes3CommentsConnecting USB-drive not working on 6.3.3 (Beta 7)
ReadyNAS Ultra 2 Plus OS 6.3.3-T138 (Beta 7) and 6.2.3-T1730 (Beta 7) Upgraded from 6.3.3 (Beta 6) to 6.3.3 (Beta 7). Now it's not possible to connect my USB3-drive to the front port on the Ultra 2+. The two back USB2-ports are working. I'm not shure if I had this problem with Beta 6. Downgraded to 6.2.3-T1730 (still Beta 7) and now it's working fine.2.7KViews0likes3CommentsBrowsing external USB-drive not working. Update Feb 21.
ReadyNAS Ultra 2 Plus OS 6.2.3-T1703 (Beta 5) Browsing connected USB-drive is not working in Backup. I can only browse down to "external/media/USB_HDD_1". Browsing the same USB-drive works fine in Shares. 21 Feb: Updated to 6.3.3-T137 (Beta 6): Browsing USB-drive working.1.9KViews0likes0Comments
