xfinity extender
1 TopicWN2000RPTv2 installation connection issues
My inlaws have an xfinity wireless router for their condo, which is rectangular shaped. Of course, the router was placed in the far end of the 3 bedroom condo and coverage at the opposite end is weak. I had purchased this WN2000RPTv2 extender a while ago and now we're suddenly having some problems. Initial configuration seems to be ok, creating the proper MYSSID_EXT naming. I can even access the internet and surf. However, I cannot access mywifiext.net. I try via different browsers, direct ethernet connection, IP address, etc. No luck. I've reset the extender and same results. Ultimately, the extender loses internet connectivity. I did this twice via manual setup. (1) Any suggestions on what to do to fix this issue? (2) With xfiniity, is there a suggestion for a better configuration and extender for this situation? Thanks.2.6KViews0likes1Comment
