mdezrin's avatar
mdezrin
WN2000RPTv2 installation connection issues
My inlaws have an xfinity wireless router for their condo, which is rectangular shaped. Of course, the router was placed in the far end of the 3 bedroom condo and coverage at the opposite end is weak.
I had purchased this WN2000RPTv2 extender a while ago and now we're suddenly having some problems.
Initial configuration seems to be ok, creating the proper MYSSID_EXT naming.  I can even access the internet and surf.
However, I cannot access mywifiext.net.  I try via different browsers, direct ethernet connection, IP address, etc. No luck.
I've reset the extender and same results. Ultimately, the extender loses internet connectivity.
I did this twice via manual setup.
(1) Any suggestions on what to do to fix this issue?
(2) With xfiniity, is there a suggestion for a better configuration and extender for this situation?
Thanks.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello mdezrin
    I would make sure the wireless network is using WPA2 security and you also may want to look for a allow list on the router you may have to add the Ip of the extender in it for it to work.
    DarrenM
