mdezrin
Jul 09, 2017Aspirant
WN2000RPTv2 installation connection issues
My inlaws have an xfinity wireless router for their condo, which is rectangular shaped. Of course, the router was placed in the far end of the 3 bedroom condo and coverage at the opposite end is weak...
DarrenM
Jul 13, 2017Sr. NETGEAR Moderator
Hello mdezrin
I would make sure the wireless network is using WPA2 security and you also may want to look for a allow list on the router you may have to add the Ip of the extender in it for it to work.
DarrenM
