xr series
2 TopicsNew - XR1000v2 Firmware Version 1.1.2.34 Released
Release Date: December 10, 2025 Security Fixes: This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security Download Link: https://www.netgear.com/support/product/xr1000v2 This version of FW is for the V2 model of the XR1000. Is NOT compatible with the v1 version. Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 This article applies to: Gaming Routers (1) XR1000v2 Let us know how it works for you...Please leave feedback in a new post here: Nighthawk Pro Gaming Routers | NETGEAR Communities Enjoy.130Views0likes0CommentsNew - XR1000v1 Firmware Version 1.0.2.86 Released
Release Date: October 27, 2025 Security Fixes: Fixes security vulnerability issues. For more information about security vulnerabilities, visit https://www.netgear.com/about/security/ Download Link: https://www.netgear.com/support/product/xr1000 Firmware Update Instructions: To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page. NOTE: Nighthawk app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too. To Manually update FW on the router if this isn't seen on the routers web page: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files. https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200 This article applies to: Gaming Routers (1) XR1000 Let us know how it works for you...Please leave feedback in a new post here: Nighthawk Pro Gaming Routers | NETGEAR Communities Enjoy.217Views0likes0Comments
