Reply
WAC720 and WAX610, How to setup a same SSID with this APs
called_sepp
Hello,
can the Netgear WAC720 and the WAX610 work together in the same network?
Message 1 of 3
schumaku
Guru
Re: WAC720 and WAX610, How to setup a same SSID with this APs
@called_sepp wrote:
,can the Netgear WAC720 and the WAX610 work together in the same network?
Definitively yes:
Either use the same flat IP network, or the same SSID mapped to a VLAN.
Key is using WPA2-PSK (WPA2-Personal) on all access points, because of the WAC7xx does neither support WPA3-SAE nor the Insight supported/-based cloud based roaming.
Message 2 of 3
called_sepp
Thank you very much.
Message 3 of 3
Discussion stats
  • 2 replies
  • 372 views
  • 1 kudo
  • 2 in conversation
Announcements
