Orbi WiFi 7 RBE973
Reply
Connect Pr60x dual wan router to MS510TXUP switch via SFP port
jstu00
Follower
I have a netgear dual wan PR60x that I’m trying to connect to a netgear multi-gig switch via the high speed SFP ports. Is there anything special I need to do to make this work? Do I need to remove the RJ45 patch between or config anything?
Message 1 of 2
schumaku
Guru
Re: Connect Pr60x dual wan router to MS510TXUP switch via SFP port
I don't think so....
@jstu00 wrote:
Do I need to remove the RJ45 patch between ...
Yes, multiple LAN connections can cause a loop.
@jstu00 wrote:
... config anything?
Experiencing any specific issue?
The links between the PR60X LAN 4 port and the MS510TXUP 9F resp. 10F ports are showing active (LED on either side)?
What are you using for establishing the connection of the SFP+ link? DAC cables, or optical modules with the appropriate fiber?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 203 views
  • 0 kudos
  • 2 in conversation
Announcements
