- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNAS Duo still running!
- Mark as New
- Bookmark
- Subscribe
- Permalink
-Hello everyone, I just wanted to say how pleased I am that my old ReadyNAS Duo circa 2010, maybe earlier, can't remember when I bought it, is still running strong! I've had a lot of stuff happen in my life, but other than a few drive replacements, this thing has held my data for so many years, never failed. The only issue is accessing the Front view, only old versions of browsers allow this kind of access.
This is by far the best piece of hardware I've ever owned!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
My own Duo is about the same age, and is also still working. It doesn't have the capacity for my data now, so it is a secondary backup.
(RAID isn't enough to keep your data safe, so you do still need a backup on another device).
The current version of FireFox will work if you set security.tls.version.min to 1 (browse to about:config and search for the setting).
There's also the mod here:
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNAS Duo still running!
Mine is still ticking too. Got mine around 2009 as I recall. Took it offline when I got a WD EX4 (much larger capacity). Brought back online last year as my WD is now EOL to back up the EX4. Had the usual issues with SSL. Applied the "fix" and all is well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@EngineerRS wrote:
It’s been working well until I tried to but a bigger disk in.
Disk size is limited to 2 TB. Many 2 TB drives are SMR, and they should be avoided.
@EngineerRS wrote:
Does anyone know the meaning of disk LEDs blinking alternatively?
LED blink behavior for 2 disk systems is three quick blinks of all disk LEDs and the backup LED, followed by an 1s delay, followed by a number of slow blinks. The number of slow blinks will be the error code.
Current error codes:
1 - Vendor mismatch
2 - No disks detected
3 - Bad contents on root partition of disks
4 - Flash error
5 - Unsupported RAID configuration
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mine still has the Seagate Barracuda Green drives in it from 2011!!
