Orbi WiFi 7 RBE973
Reply
Netgear Insights Client isolation
matherton
Hello I have a network managed in Netgear Insights.  I'm trying to figure out how I can configure an easy to connect to Guest Network.  I want this to be an isolated network.  I've read that using Client Isolation can accomplish this.  I went into my insights portal and into my guest SSID.  I enabled client isolation on the SSID.  I then connect to the guest network, and check to see if my device is isolated.  I find that it's not isolated.  I can see everything on the network, access file shares, etc.  Is there something that I'm missing with client isolation?
Message 1 of 3
schumaku
Guru
Re: Netgear Insights Client isolation
Client isolation does only isolate other devices from talking direct to each other through the network.
For a guest network, there is no other way than having a capable router supporting multiple VLANs and IP subnetwork, and configure the environment accordingly. For the sake, including the client isolation.
Message 2 of 3
matherton
Do you happen to have any documentation on configuring a VLAN with insights?
Message 3 of 3
Discussion stats
  • 2 replies
  • 2176 views
  • 1 kudo
  • 2 in conversation
Announcements
