× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Compression effectiveness?
PeteMoran
Star
We use a RN104 (which replaced a standalone companion PC) to save Windows Image backups and database file dumps before transfer offsite.
The Windows system images were quite compressible using NTFS compression.
The database file dumps were highly compressible.
For example;
A 333,520,896 byte file gives the following results;
NTFS 126,586,880
ZIP 57,962,496
BZ2 48,298,874
As near as I can tell, unless there is another method of checking (used 'ls -l' from ssh), the ReadyNAS on-disk size is 333,170,328, barely 1% saving and hardly worth the effort.
Consequently, the client is not getting the historic file saving ability we expected.
Are our expectations too high? Firmware is 6.2.4.
Message 1 of 3
Accepted Solutions
Guru
Re: Compression effectiveness?
https://btrfs.wiki.kernel.org/index.php/Compression#How_can_I_determine_compressed_size_of_a_file.3F
Based on the wiki link, I think you need to do a df before and after compression.
Message 2 of 3
All Replies
Guru
Message 2 of 3
PeteMoran
Star
Thank you. Great reference.
Looks like our files might suffer from "if the first portion of data being compressed is not smaller than the original, the compression of the file is disabled" because the df -k result shows ~72,810kbytes if force compression is on.
Seems like the compress decision is made on the first 4k block of data for the file.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4032 views
  • 1 kudo
  • 2 in conversation
Announcements
