Retired_Member
Jun 21, 20171.11.0.20 Firmware Problems w/ Satellites
Both of my satellites along with the master router received the 1.11.0.20 update yesterday.
Upon restart of all 3, the satellites and all clients attached to them no longer show connected in the Atttached Devices screen on the master router. The Firware update screen also does not reflect the satelites, however, clients connected to the satelites are connected to the WAN/LAN.
The guest network no longer shows present on the satellites after the firmware upgrade.
I have factory reset the router and satelites twice.
- Retired_MemberJun 30, 2017
I can confirm that the 1.12.0.16 beta corrects the sats not showing up in the Attached Devices and Firmware Upgrade pages of the router. Now if it is as good as everything has been for the past 6 months, except for the issue in 1.11.0.20 with the sats, I'll be in great shape!
- DarrenMSr. NETGEAR Moderator
Hello TxGunLover
what about when you log into the satellites what are they showing in the attached device.
DarrenM
- Retired_Member
Hi Darren,
One satelite shows different devices connected than the Router does. The other satelite just spins the "Please Wait A Moment" indetermininte loader for ever.
Thank you.
- Retired_Member
Just as an update, I manually loaded the firmware on the satelite that wasn't hung showing Attached Devices.
After re-flashing, it now behaves like the other satelite and shows devices not connected to that satelite or the router.
Both satelites are still not shown on the Router in Connected Devices or in the firmware upgrade page. Thank you.
I have the same problem with my satellite after the upgrade. I have reset the satellite to factory default twice. I know the satellite is online since I can print to the printer that connected via network cable to the satellite. However I did not see the satellite on the console.
- Retired_Member
Yep, that's the exact same situation I'm in. I've spent an inordinate amout of time trying to get the router to reflect the satelites, but to no avail.
- JMU1998Luminary
Does the current Beta address this issue?
- https://community.netgear.com/t5/Orbi/Orbi-Router-QOS-Setup/m-p/1298498
Try to see my post, same situation. Sat keeo rotating dots. Have u try to click speedtest?- Retired_Member
Manually reloading the firmware on the Sat fixed rotating dots for me, but not the problem of being able to see the sats from the router (even though they are connected, they're not reflected in the UI).
- YabbadabbaDooooApprentice
@TXGunLover wrote:Manually reloading the firmware on the Sat fixed rotating dots for me, but not the problem of being able to see the sats from the router (even though they are connected, they're not reflected in the UI).
Again, hope I do not insult your intelligence but have you tried to connect the Satellites using the full administrator UI in the Router? I was having a problem with my one satellite connecting and ended up starting over using the Router Admin and not the App or other. Worth a try....
Try to see my post, same situation. Sat keeo rotating dots. Have u try to click speedtest?Yes I did, several times and got a consistent 120Mbs Download and 6.5Mbs Up. That is near the max speed of my Xfiniti service.
I have an RBK53 running fw 1.4, I haven't added the second satellite in yet. I assume I should hold off on the upgrade?
These have been a total dumpster fire to setup. The number of non-responses and hard reboots required should be embarassing to the company, designers, and QA. Did they even test this? The level headed say "of course", but there is no answer to the quantity of issues and failed basci steps (like IP and SSID changes) requiring hard reboot.
- A better solution is to return it for a refund, which I'm about 2 more uncalled-for reboots away from doing.
cmschleich wrote:
A better solution is to return it for a refund, which I'm about 2 more uncalled-for reboots away from doing.Man i feel ya. I have my return label from Amazon printed and ready to go. The strange thing is that I am having the opposite experience from TXGun.... I had nothing but problems until 1.11.0.20. Now it is working perfectly and while I hope it stays that way, I will be sending it back if it acts up again this week. If it makes it through the week I will let it ride. Damn shame with all these problems bc when the system works like it should it is outstanding.
Wow. From everything stated so far it sure looks like the new Firmware fixed the issues with the RBK40 and screwed up a bunch of things on the 50. I haven't seen anyone post about this issue happening on the RBK40. Maybe it is on another thread. Good luck y'all. I definitely know the frustration. I am repeating the link to the release notes for 1.11.0.20 if anyone is interested. It only talks about the RBK40 bugs fixes.
https://kb.netgear.com/000038848/RBR40-RBS40-Firmware-Version-1-11-0-20
- quentinAspirant
how i would get a copy of this version. 1.12.0.18 ?
I am using it version. 1.12.0.16I just go to firmware update tab and click check update. then i see status changed it's downloading firmware.
- quentinAspirant
I'll try it !
thank you!!
- nelsonahmedAspirant
My router updated last night automatically to the newest firmware version 1.12.0.18 but my satellite still doesnt show. Is there a way that I can manually update the firmware on the satellite? I have tried everything on the Netgear support page, but I cant uptdate the satellite since it isnt showing up on attached to my router. Thank you
Thank you. Just did a factory reset on both units, synced them and then I was able to manually update the satellite to the latest firmware. Thanks again!
did a factory reset on both units and synced them did the trick for me as well. now I can see the satellites.
