tomsliwowski's avatar
tomsliwowski
Apprentice
May 03, 2017
1700Mpbs backhaul much slower than 1000Mbps wire?
So I've had the Orbi system for 3 days now and it's worked well for wireless clients but I was wondering if I'm doing something wrong in regards to placement or configuration.
My setup is the following: Orbi router in the basement connected directly to a FiOS ONT with a Windows 2016 Server and a Zigbee bridge connected to LAN ports 1 and 2. Orbi Sattelite on the other side of the house on the ground floor with LAN port 1 connected to a Windows 10 Pro desktop. I have about 16 other wireless clients like a few Windows laptops, a Linux laptop, some Android phones and Amazon FireTV devices.
The WiFi seeems to be working great and when I check the connection stats it shows that the backhaul is running at 1733Mbps. The hardwired server and desktop have 1Gbps links so in theory the backhaul should saturate the links (or at least come close to). When copying a large file from the server to the desktop I'm only getting about 30-40MBps which translates to 240-320Mbps. When the setup was hardwired on my R7000 router I was getting 100-110MBps which is 800-880Mbps. What could be the reason for such a huge disparity? I would expect the throughput to be much better than what I'm currently getting considering what the system tells me is available.
  • 1733 is max theoretical, not real world.  Reality is about half that under ideal conditions, less depending on the distance and obstructions between the router and satellite.
    Rodney
    • tomsliwowski's avatar
      tomsliwowski
      Apprentice
      I know that 1733 was the theoretical max but I thought the days of WiFi overhead taking up half the available bandwidth died with 802.11g. I recall getting a LOT closer to max on 802.11n and definitelly close to the 866Mbps on 802.11ac.
      • st_shaw's avatar
        st_shaw
        Master
        WiFi still has lots of overhead, so 50-60% of the link speed is all you will get.  I measure 575 Mbs throughput over my Orbi backhaul using iperf3.
