  • Going to 2.0.14 from the 2.1.2.18 release, you would lose wired Ethernet backhaul, and support for the Orbi outdoor satellite.  If you need neither, you could downgrade,
    Whether you should depends on your circumstance.  If you're having issues, you might want to try.  If not, I would not bother.   2.0.1.4 in my environment is not without problems, but appears to be the best version I've tried (and I've tried many versions so far).
    • rhester72's avatar
      rhester72
      Virtuoso
      What changed between 2.0.0.74/76 and 2.0.1.4?
      EDIT: Looks like it added KRACK protection over 2.0.0.74 and addressed a satellite memory leak.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Landerx
    If you are not having issues with the 2.1.2.18 firmware then no reason to switch. 2.1.2.18 Does have Disney circle and Ethernet back haul and the 2.0.1.4 does not.
    DarrenM
