la79's avatar
la79
Apprentice
Feb 20, 2018
401 Unauthorized Access Netgear ORBI
Hello everyone. Lately whenever I try to login into my router via ip address (192.168.1.1) I am faced with a 401 Unauthorized Access screen. I'm asked to put my Orbi Serial number in and I'm forced to answer my login secret questions. It then provides me with my login password and will allow me to login.
Lately this has been happening all the time. Is this happening to anyone else? If so, do you know if there is a fix for it? Or should I be worried?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello la79
    Have you tried to use a different web browser?
    DarrenM
    • la79's avatar
      la79
      Apprentice
      Yes, I was able to try with Mozila Firefox and didn't have that problem. However it seems like it has gone away.
      • TommyJay's avatar
        TommyJay
        This is happening to me too. I'm using both Safari and Chrome browsers and get the same thing. I had been using Comcast and no problems. We then switched to Fios and that's when the problems began. My Orbi is now useless! very frustrating...
