Maddie459's avatar
Maddie459
AC Adaptor
Hi everyone ,
I have a orbi rbr20 with 2 satelites rbs20. All is working fine until 1 of the AC adaptors stop working . Not sure how best to replace the adaptor which is input of 220-240V , 50-60Hz and output of 12 V 1.5 A
Appreciate assistance and advice.
Thank you !
Maddie
  • plemans's avatar
    Netgear doesn't sell replacement power supplies.
    But you can use any power supply so long as it has matching output voltage and polarity and at least the same amperage.
    It can have more amperage but I wouldn't go less.
  • michaelkenward's avatar
    michaelkenward
    As plemans says, it will probably have to be a generic adapter. I chip in only to say that you can often find these in the usual places and many will go so far as to claim compatibility with Netgear devices.
    First, dig around at home. You may have something lying around from an old device that will work. Follow the advice from plemans on what to look for.
