marin21's avatar
marin21
Follower
Apr 17, 2019
AC3000 Problem with Wifi connection every minute
Firmware V2.3.1.44
Replaced my old router yesterday evening with the Orbi (with one satellite) and it worked well for a while.
This morning the wify disconnects every minurte or so on both laptops and iphones.
- Using an eithernet cable works fine.
- I have tried using different channels on both 2.4 and 5Ghz network.
- Tried disable 20/40 MHz Coexistence
- Tried disable Daisy-Chain Topology.
- Tried Enable Implicit BEAMFORMING
- Tried different Preamble Mode
The only difference from yesterday I can think of is if the router have upgraded its firmware in the background.
If I switch back to my old router it works ok as usual, (slow and poor range as expected).
Frustration is running high and I have not got a black belt in networks and wifi and hoping for a noob problem/solution... ;)
Regards
Peter
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
  • FURRYe38's avatar
    Any progress on this?
    marin21 wrote:
    Firmware V2.3.1.44
    Regards
    Peter
