Dogzelda's avatar
Dogzelda
Follower
Jan 24, 2019
access router configuration
I am running my Orbi system behind an ATT Uverse router. I have it setup in AP mode with the wifi on the router turned off. Everything works great. I need to access the router to configure port forwarding changes. Previously I accessed the router using 192.168.1.254. With the ORBI interface I can no longer access the router through the normal ip address. Does anyone know how I can make changes to the main router with the ORBI in AP mode
1 Reply
  • Orbi should not have any effect on the IP addressing as this is all managed by the ATT Uverse router. you should still be able to reach the router on 192.168.1.254 if you did not change the IP address range in the router.
