drftorres
Jan 09, 2019Aspirant
Add another Orbi RBR20 router via LAN cord and still use same SSID
I have purchased two main RBR20 routers, one of them with 2 satellties and the other one with 1 satellite. My apartment is big, so satellites are not enough. My main fiber cable internet is located in the master room, therefore I placed my main router (RBR20) over there. I installed a LAN cord to the other side of the apartment and placed the othe router (RBR20) connected via the LAN cord that comes from the main router. I have internet everywhere, but when I walk it switches from wifi to wifi. When I open the Orbi app and check the "Network map" I can only see the router I am connected with some sattellites. How can I set up all the equipments together in the same network map?
Thanks
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?What is the Mfr and model# of the ethernet switch if one is in the configuration.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. Wired or wireless.By using two RBR units you have two different wireless and networks systems. This is NOT recommended. RBR units can only run as main routers or AP mode. All you need to do is replace the remote RBR unit with a RBS unit. You use the RBS units using wired backhaul where needed.
Also Daisy Chain needs to be disabled if you have the RBS connected via LAN cable.
Thanks
