Auggie11
Jan 25, 2020Aspirant
Adding a satellite
Hi,
I currently have the below system that has two wall plug satellites. I would like to know if I can add the RBS50 satallite as I have LAN connections in many rooms. Will it work with my existing system?
Thanks
Current system is Orbi WiFi System (RBK33) with two plug satallites.
Want to add:
RBS50 — Orbi AC3000 Tri-band WiFi Add-on Satellite
Yes. All Orbi satellites can be used with all Orbi routers.
Orbi AC satellites are not compaible with Orbi AX systems currently. NG is supposed to make them compatible. I believe some of them and not all. No time frame on when this will happen.
