Elgreco3's avatar
Elgreco3
Adding a second orbi satellite
I have an RBK50 dual pack.
(Router plus a satellite)
I want to add another satellite to cover an upper floor of my house but because my router is in the basement and the satellite
is in the main floor, I plan to run an ehternet wire from my basement router all the way up to the second satellite.
Is this going to work fine ? while my first satellite remains wireless.
I just want to make sure before I purchase it.
Thanks.
  • FURRYe38's avatar
    Yes you can add another satellite. Others have posted having 4 and 6 added.
    30 feet is recommended in between them to begin with depending upon building materials.
