Elgreco3
Nov 12, 2018Aspirant
Adding a second orbi satellite
Hi guys.
I plan to add a second satellite and wanted to know if instead of just buying a satellite off Amazon as a single unit, could I get another dual pack (router +satellite) and just add the satellite to my existing system?
Mostly because the price for the pack is even lower than just buying the satellite alone. Crazy..
Thanks.
Thanks.
- ekhalilMaster
Yes, you can use the satellite from the “dual pack” to expand your system with an extra satellite. But the router in the pack can’t be used as a satellite.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Elgreco3 wrote:
Hi guys.
Thanks.- Elgreco3Aspirant3 floors total.
Router in basement, first satellite in middle floor and now I want to add anither satellite upstairs.
Btw, plan to use the second satellite wired to the router because of the distance,
So I just want to buy another but if I can use the satellite from another combo, then it's cheaper.
That's all.
