dwatts44
Nov 22, 2025Follower
Adding new products into old mesh?
Hi I have a fairly old network (AC2200 router and RBS20 satellites). One of my satellites seems to be dying (it keeps dropping the connection and needs rebooting). Can I buy a replacement of ...
Nov 22, 2025Guru - Experienced User
dwatts44 wrote:
Can I buy a replacement of one of the current models and just put in to my network? Will it work?
No, but there are some used satellites you could choose from. Netgear's compatibility chart is here:
- https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
