Serafin630
Jul 07, 2017Tutor
Advantages/Disadvantages to using Orbi RBK50 pair as Wireless Access Points
I use an xFinity wireless router/modem for internet, wireless and VOIP. I understand that I could use the Orbi RBK50 units as access two wireless access points for this router, but am wanting to kno...
cyberprashant
Jul 10, 2017Luminary
Orbi seamless roams well even though it may not support true enterprise roaming. I had a 2 access point setup over ethernet (or actually over powerline adapters to ethernet) - worked well (R8000 and R7000) but you will lose out on seamless roaming if that's an issue. wifi extenders are laggy and generally suck (i tried the linksys re6700 and wasn't impressed)
